LabVIEW Interface for Arduino Documents
AdafruitMotorshieldVersion2DCMotorExample
Attached is an example using version 2 of the Adafruit Motor
Shield for use with one DC motor. This example does not use LIFA.
Note the following procedure assumes you have installed the
Adafruit Motor Shield Version 2 on your Arduino Uno, connected a DC
motor to Motor Port M3.  If you use a different Motor Port you need to modify
this line of code  "Adafruit_DCMotor *myMotor = AFMS.getMotor(1);"
in the sketch.  Here 1 means Motor Port M1.  For Motor port M2 replace
the 1 with 2,  For Motor Port M3 replace the 1 with 3 and for Motor Port
M4 replace the 1 with 4.
The preferred power supply voltage for this shield is 12 volts DC.  Maximum
power supply voltage rating is 13.5 volts DC For additional information on using
the Adadfruit Motor Shield V2 with DC motors se:
<https://learn.adafruit.com/adafruit-motor-shield-v2-for-arduino/using-dc-motors>
Installation Instructions
1.  Use 7zip to unpack AdafruitMotorShieldVersion2DCMotorExample.zip.
If you don't have a copy of 7zip you can get a copy here.
<http://www.7-zip.org/>
2.  Move the Adafrit_MotorShield  library to your Arduuino IDE "libraries" folder.
3. Move the DCMotorTestVersion2  sketch folder to your Arduino sketch folder.
4. Move the AdafruitV2MotorShieldDCMotorContrller.VI  to your your collection
of Labview examples folder.
5. Compile and download  the DCMotorTestVersion2sketch to your Adruino Uno.
Operating Instructions
6. Open the AdafruitV2MotorShieldDCMotorContrller.VI
7. On the front panel set the serial Port to your Arduino
Uno's COM port
8. Set the baud rate to 9600 bits per second.
9. Run the VI.
10  Set the "Speed"  to a value between -255 and 255.   The motor rotates
BACKWARD when the value is negative, FORWARD when the value is positive
and stops when the value is 0.  Maximum BACKWARD speed occurs when the
value is set to -255.  Maximum FORWARD speed occurs when the speed is set
to 255.
11.  Click on the "Send" button to send the "Speed" value to
the Arduino Uno and to start the motor rotating.
12.  Most DC motors have considerable friction and will not rotate if the "Speed"
is set to to low of a value.  You may need to use a "Speed" value of 25 or higher to
13.  When reversing directions Adafruit recommends stopping the motor before
reversing the direction of rotation.
14.  To quit click on the "Stop" button.
hrh1818
Contributors
