LabVIEW Interface for Arduino Discussions
ADC more faster - not 35-40 samples per second - but 400-1500!
When I using a base flashing and LIFA_base.pde with Arduino Uno on file is written with 35-40 measurements per second and no more. How to increase sample per second - or the same configuration in the LabVIEW Interface for Arduino toolkit or edited prescaler by changing the prescaler LIFA_base.pde or the other way. Valent_S
(4,045 Views)
Hi Valik,
I had a similar problem, and it was due to how I was building the array before saving not sure if this is the problem but maybe you could put your code up for others to see and comment?
Canalian
(3,104 Views)
