LabVIEW Embedded
rt fifo in an interrupt routine
I was wondering if the writing to an RT fifo inside of an interrupt routine was supposed to work? I create the fifo in the application vi and call the fifo write within a gpio fifo, but every time the fifo write is called the micro hangs. I using the Luminary micro eval board.  Thanks
(5,760 Views)
Hi Ed,
Could you post some example code so that I can see what you are doing?
Justin Parker
Product Support Engineer
(5,754 Views)
