LabVIEW Embedded
取消
显示结果
搜索替代
您的意思是:
rt fifo in an interrupt routine
I was wondering if the writing to an RT fifo inside of an interrupt routine was supposed to work? I create the fifo in the application vi and call the fifo write within a gpio fifo, but every time the fifo write is called the micro hangs. I using the Luminary micro eval board.  Thanks
0 项奖励
1 条消息(共 2 条)
5,758 次查看
Hi Ed,
Could you post some example code so that I can see what you are doing?
Justin Parker
Product Support Engineer
0 项奖励
2 条消息(共 2 条)
5,752 次查看
