LabVIEW Embedded
program the mcb2388 using the Ulink-ME
Dears, I will buy a MCB2388 board with its debugger and flash programming ULINK-ME , so is this flash programming device (ulink-Me) compatible with labview embedded for ARM, simply can it be used with labview to program the ARM evaluation kit Thanks Ahmed
(5,887 Views)
Support for LabVIEW for ARM is only officially support when using the ULINK2 J tag connector. The Ulink-ME might work, but it is mot offically supported.
(5,881 Views)
