LabVIEW Embedded
How can I create code for PIC and Freescale microcontrolles and perform simulation?
Hi. I am new to LabView.
I would like to simulate code (C or assembly) for the PIC and Freescale microcontrollers. I would further like to
use oscilloscope to monitor the pins behavior. Is this possible? If yes what software should I use?
Please feel welcome to suggest any resources that might be helpfull.
(5,839 Views)
Hi SweetOrange,
If you have a vi you would like to run on a PIC or Freescale microcontroller and have a compiler for these devices that recognizes C, you can use the C Code Generator to create C code that your compiler can use.
<Brian A | Applications Engineering | National Instruments>
(5,830 Views)
