LabVIEW Embedded
fpga
I work with cRIO 9004 and modules: NI 9853, 9401, 9203, 9201, 9411, 9265, 9481.
My FPGA VI (LabVIEW 8.2) works with delay about 5 seconds. Though the same VI in LabVIEW 7.1 react at once. I can't work with LabVIEW 7.1, because LabVIEW 7.1 don't supports NI 9853 and 9203.
Help me, please...
Olga
(7,879 Views)
Hello!
Please look at shipping examples on proper architectures and layouts. I am not sure what you are trying to achieve but if you convert binary values from analog input operations for an example to nominal values on the real-time side I recommend you perform calibration. If you are unsure how that works, once again, just look at any of the analog input examples for cRIO (module specific examples). Also might be better to post on the LabVEIW FPGA forum instead of this one. Good luck!
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(7,764 Views)
