LabVIEW Embedded
connect ls330dl to lpc2468 with i2c
hi all !
I want to connect to lsm330dl lpc2468 by i2c. datasheet for lsm330dl http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/DM00034579.pdf
lpc2468 has 3 i2c. how to choose the 0.1 or 2?
this my vi. where I could make a mistake?
thank you
(6,182 Views)
Hi Sergiv,
I think that most of your answers can be found in this post: How to implement an I2C Bus with Labview embedded
In that post, Kevin lets us know that our VIs are hardcoded to use port 0 for the lpc2468.  Can you test writing to port 0 and see if you are outputting a signal?
Also, if you want to learn more you check out this article:  Where Can I Get More Information on the LabVIEW ARM Module's I2C VIs?
I hope this helps.
Justin
Justin Parker
Product Support Engineer
(6,167 Views)
Thanks for your reply. I've seen you specify a theme, but the solution is not found, unfortunately. oscilloscope is not, so I can not see the signal at the output. Why use only 0 port? My scheme in the application. Thanks for your help.
(6,164 Views)
Hi Sergiv.  I don't know the exact reason that design decision was made.  Are you running into issues using port 0?
Justin Parker
(6,152 Views)
Hi, Justin_P. Yes, I use port 0
(6,150 Views)
