LabVIEW Embedded
cRIO 9073 remote subnet tutorial
Matt is correct.  The watchdog and system state publisher should be installed with the LV Real-Time module.
In general, software for your target comes from three sources.  In any case, it always has to be present on the host machine first.
1.  The LVRT module - quite a few packages come with the module itself, like the ones mentioned above.
2.  Drivers - Many drivers include real-time components.  For example, if you wanted to use DAQmx on a Real-Time PXI system, you would first install DAQmx for your host system, and the real-time driver would come along.  For cRIO, the main driver you'll need is NI RIO, but there are a couple of others such as the IndCom (EtherCAT) driver.
3.  Individual packages - fairly uncommon, but there are a few cases where you can download something that just contains a package for your LVRT target, this would be an example
http://zone.ni.com/devzone/cda/epd/p/id/6371
Message 11 of 11
(748 Views)
