02-21-2010 06:01 PM
Can someone explain to me when I would use the following toolkits:
Microprocessor SDK
Embedded ARM
Touch Panel
I am asking because I just purchased http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=330375626989&ssPageName=ADME:L:OU:US:1123
I'm looking to create an HMI application that will communicate over ethernet to a controller and also control some onboard I/O ports.
What will I need to create and control my app?
02-22-2010
01:09 PM
- last edited on
10-31-2025
08:45 AM
by
Content Cleaner
The choice is yours and depends on experience, the DVD content and support, and market plan. (http://zone.ni.com/devzone/cda/tut/p/id/5773)
On the one hand, an optimum solution in terms of hardware requirements or power consumption would be LabVIEW for ARM since the microprocessor is ARM9 it is supported by Keil (http://www.keil.com/dd/chip/4277.htm). On the other hand, the first product developed will not have a so short time to market, because you have to develop the BSP and low level VIs (see the tutorial http://zone.ni.com/devzone/cda/tut/p/id/6994). However, the effort is rewarded when designing next projects.
Probably your board came preloaded with Linux. Microprocessor SDK fits better if you want to keep it there.
If Windows is OK, then time to marker will be shorter in Touch Panel starting with the first product.
02-22-2010 01:13 PM
02-22-2010
01:38 PM
- last edited on
10-31-2025
08:45 AM
by
Content Cleaner
This is not a so hard task because you have multiple choices again (e.g. call library function, Inline C Node, etc.)
The problem is I am not sure if ARM9 is supported in Touch Panel (http://zone.ni.com/devzone/cda/tut/p/id/9850#toc3).
Probably couple NI guys can help in this issue.
02-22-2010 08:16 PM
02-23-2010
04:41 PM
- last edited on
06-15-2026
05:07 AM
by
Content Cleaner
The Touch Panel Module is only supported on NI Touch Panels. It might work on other Windows CE devices, but it's not guaranteed. If you are trying to put LabVIEW on an ARM device, you should probably look at the NI LabVIEW Embedded Module for ARM Microcontrollers .
02-23-2010 04:43 PM
