LabVIEW Embedded
WebServer on sbRIO
Hey Guys,
I am trying to make a webserver application on an NI 9636 sbRIO. I think I have all the necessary software installed on the target.
I have built the webserver Build Specification and I can see the deployed webserver under the "Deployed Web Services" option of the NI Web based Configuration & Monitoring tool (screenshot attached).
I attached a demo project, which has the sbRIO target with a "static" folder (this includes index.html), and the webserver Build Specification. The deployed webserver is shown in the attached screenshot. When I try to open 192.168.1.180/RIO_WebService/static/index.html, I get error 404.
Do you have any suggestions why I cannot open the index.html page?
I almost forgot: With the exact same configuration steps, I can deploy and reach the webserver on a desktop pc without any problems.
I hope I made it clear what the problem is. I you need any further information, please ask!
Thanks in advance,
Norbert
(7,875 Views)
Accepted by asdf_1234
Hi Norbert and welcome to NI Forums!
Did you try to access it using the port configued in the Web Application Server? So in your case, 192.168.1.180:8080/RIO_WebService/static/index.html or something similar.
The web service setup looks good to me.
Kind regards:
Andrew Valko
NI Hungary
Andrew Valko
National Instruments Hungary
(7,848 Views)
Hey Andris,
Thanks, that was the catch 🙂
Have a nice day,
Norbert
(7,844 Views)
