LabVIEW Embedded
Warning: Inconsistent Arg. You cannot have Use Stack Variables set if Generate Serial Only is not set
What does this message mean?
"Warning: Inconsistent Arg. You cannot have Use Stack Variables set if Generate Serial Only is not set."
 Where do I set Generate Serial Only?
Derek
(6,839 Views)
Accepted by Derek Price
Hi Derek,
Not all of the LabVIEW C Generator settings are compatible with one another. In this case, you must set Generate Serial Only (aka "Disable Parallel Execution") if you want to generate code that uses stack variables.
Michael P
(6,824 Views)
Hi Micheal,
Thanks for the info.  Not exactly clear message, though? ...
Derek
(6,814 Views)
