01-01-2014 11:35 AM
Hello can anyone help me with this error. Installed on both laptop and computer and both gives me error. Also uninstalled, reinstall and still error! Any help please?
01-02-2014 01:23 PM
Hi there,
What version of LabVIEW and LabVIEW Embedded for ARM are you using? And what version of the uVision software do you have installed?
I would recommend a repair of the LV Embedded software, although you have said you have already done so. Try also reinstalling the Keil uVision software; this must be done after any installation of the LV Embedded software.
Be sure to follow all the steps outlined in the installation manual for the LM3S8962 Evaluation Board: http://www.ni.com/pdf/manuals/375177c.pdf
Here are some other forums that discuss a similar problem to yours. I would read through those and see if any of their problems are similar to yours.
http://forums.ni.com/t5/LabVIEW-Embedded/My-first-ARM-VI-does-not-compile/td-p/1333998
http://forums.ni.com/t5/LabVIEW-Embedded/uVision-Build-Tools-Error/td-p/892541
Best,
