LabVIEW Embedded
Source: UVSC_OpenConnection Code: 1
Hello can anyone help me with this error. Installed on both laptop and computer and both gives me error. Also uninstalled, reinstall and still error! Any help please?
(6,771 Views)
Hi there,
What version of LabVIEW and LabVIEW Embedded for ARM are you using?  And what version of the uVision software do you have installed?
I would recommend a repair of the LV Embedded software, although you have said you have already done so.  Try also reinstalling the Keil uVision software; this must be done after any installation of the LV Embedded software.
Be sure to follow all the steps outlined in the installation manual for the LM3S8962 Evaluation Board: http://www.ni.com/pdf/manuals/375177c.pdf
Here are some other forums that discuss a similar problem to yours. I would read through those and see if any of their problems are similar to yours.
http://forums.ni.com/t5/LabVIEW-Embedded/My-first-ARM-VI-does-not-compile/td-p/1333998
http://forums.ni.com/t5/LabVIEW-Embedded/uVision-Build-Tools-Error/td-p/892541
Best,
Ryan C.
Applications Engineer
(6,741 Views)
