LabVIEW Embedded
Short embedded projcts
Hello Everybody !!
I need to make a small project on embedded systems ann needs to comlete it in 1 month time. ICould anyone please suggest me any idea . I am interested in working on AVR series using LabVIEW.
Please suggest as soon as possible.
Dreamliner.
Message 1 of 10
(8,755 Views)
What kind of help you need?
AVR cannot be directly programmed using LabVIEW Embedded, though you can use LabVIEW as PC interface using RS-232,Ethernet or USB. Please specify your requirement.
Certified LabVIEW Architect
Message 2 of 10
(8,754 Views)
Also,Check out this link below.
http://engineeringsolutions.in/
They offer consulting solutions for LabVIEW Embedded projects from India. They were pretty good for delivering results in my case.
Message 3 of 10
(8,749 Views)
The list seems awesome. How do I contact them ? Seems they combine LabVIEW and Microchip\ARM controllers.
Message 4 of 10
(8,746 Views)
Can you PM your contact ?
Message 5 of 10
(8,745 Views)
I have STK 500 kit. My tak is to built a project that i should be able to complete in time period of 1 month time. Since I had used LabVIEW earlier for interfacing osilloscope and function generator, I want to apply my LabVIEW programming knowledge in embedded field. So i am short of ideas and want to know what can be done.
Also it is not ncessary that i should be using AVR, I can make project on other topic, but the problm is I am not getting any idea as what to make and from whre to start.
I hope now it is clear to you.
Message 6 of 10
(8,742 Views)
I have few suggestions for you:
1. Use the ADC in the controller and acquire analog channels.
2. Transfer these values to RS232 port.
3. You may design a LabVIEW program to acquire these values via PC RS232 port and display it in a Graph\chart.
4. You may do frequency domain analysis for the acquired values to show the power of LabVIEW.
If you want a bit more complication, you can select a microcontroller with USB\Ethernet ports and implement the firmware on it to communicate with LabVIEW application running in PC. Make sure your USB firmware complies to USB Test and Measurement class(USBTMC), so LabVIEW will list this device in its VISA sessions.
I have done the USBTMC method long back and it works well.
Message 7 of 10
(8,739 Views)
Could you plz suggest me some more projects based on ARM processors and AVR ontrollers.
Message 8 of 10
(8,733 Views)
check the list below.
Seems like its a big list
Message 9 of 10
(8,731 Views)
Any other suggestion is also welcome.
Message 10 of 10
(8,727 Views)
