LabVIEW Embedded
LV ARM 2010 Stellaris GPIO vi's crash
Hi developer of the luminary StellarisWare vi's in LV ARM 2010,
Trying out the newest LabVIEW for ARM version (2010) I saw there are nice StellarisWare vi's for using different peripherals of the LM3xxxx microcontroller.
building a simple program, putting LED's of the ethernet (pin F2 and F3) on and off, I noticed that my programm crashes.
When I saw the Ring control for selecting the PORT of the pin, I saw that there are 2 GPIO_PORT_F defined! (in hex 0x40025000 and 0x40027000) it tries to use my PORT_H now, but my lm3s8962 doesn't have a PORT_H.
This is by the vi's of GPIO Pin Write.vi, GPIO Dir Mode Set.vi and GPIO Pin Type GPIO Output.vi
so I changed all the ring controls (to the developer: why not 1 TypeDef ring control!?!?!?)
and voila it worked 🙂
Also when I first build a program with LV for ARM it gives an compile error: there is missing a ; in the source code. this is in the standard LV C code. (ARM_I2CWrapper.c near line 72)
Greetings,
Wouter
Wouter.
"LabVIEW for ARM guru and bug destroyer"
(6,128 Views)
Dear Wouter,
Thank you so much for your post on our webforum. Did you noticed this KB about pin mappings?
The missing ';' is a known issue, this was reported in Correction Action Request (CAR) 249822 and will be resolved in a future release.
Martijn S
NI Netherlands
(6,114 Views)
hi  ninlmartijn,
you're welcome.
No I didn't noticed that #20 error. I see that it's for LV 8.6?
I have LV 2009 for arm and 2010 for arm. I am also using one chip, the standard lm3s8962, on a own made PCB.
If I find more I will place it on the forum 🙂
Greetings,
Wouter
Wouter.
(6,111 Views)
