LabVIEW Embedded
STM32F100RB - application is too large for target memory
Colleagues,
Is someone was able to get LabVIEW Embedded project running on STM32F100RB chip (or similar microprocessor)?
After some attempts I've got my project succesfully compiled, but finally the following error appear in Build Log:
uVision Status: Build Failed.
[07:23:42] Status: Error
linking...
Error: Application is too large for target memory.
Status: Build failed.
My application is not large - I have only single while loop in top level VI.
Whats else could be wrong?
Andrey.
(7,261 Views)
Hi Andrey
first, have you created your own arm?
second, which version of embedded do you use?
best regards
Alexander
(6,981 Views)
Thanks for the answer, Alex
Yes, I have created my own target STM32F100RB (complete folder attached)
I using latest version - LabVIEW2010SP1 and LabVIEW Embedded 2010.
I was able to build small test project in uVision (which coming from LabVIEW Embedded 2010 installer), but not in LabVIEW.
Andrey.
(6,979 Views)
Hi Andrey
sorry for the late replay i couldn´t test it, but i found a similar thread
labview for stm32f103 development board?
they have used this guide
Programming Additional ARM Microcontrollers with LabVIEW (without the LabVIEW Microprocessor SDK
How big is the mermory from the STM32F100RB?
i hope it works for you too.
best regards
Alexander
(6,865 Views)
