LabVIEW Embedded
Running Unix Console Application on X86 Linux Target
I tried to build a linux console application. I followed this tutorial http://zone.ni.com/devzone/cda/tut/p/id/5412 and it worked fine.
The result was an executable that runs on my Windows-PC.
But how can I run the program on my Debian-Linux machine (X86)?
Greets Smithee
(8,142 Views)
Hi Smithee,
The application you built was compiled with gcc for Windows. To cross-compile for a Linux PC, you would have to create your own target that calls gcc for Linux. This involves modifying plug-in VIs and possibly updating some header files. The steps in the porting process are explained in this document: http://digital.ni.com/manuals.nsf/websearch/1DE04E4CE92B5D4186257309006E1BC2.
Michael P
(8,130 Views)
I have the same problem.I want to know how to cross compile for Linux Pc in LabVIEW?
I have dowloaded cross tools for Linux.But it shows Header file errors.
Indumathi
(7,385 Views)
Hi Indumathi,
What cross compiler are you using? Most cross compilers come with example programs, can you try compiling one of those?
Senior Product Manager
(7,379 Views)
I am using GCC tool chain.i compiled it as gcc-linux.
Its showing me header file errors or says "command not found" compiler error occured.
How to resolve this?
Indumathi
(7,365 Views)
Have anyone find solution to my problems.......
(7,346 Views)
