01-29-2010 11:21 AM
Solved! Go to Solution.
01-29-2010 02:00 PM
The ARM targets use the RL-ARM flash file system. However, it looks itsupports only 4GB max.
With the Flash File System you can also write and read files from standard SD (Secure Digital) and MMC (Multi Media Card) Flash Memory Cards. They are used in SPI mode. Standard device sizes ranging from a few MBytes up to 4 GBytes are supported. Files on the Memory Card drive are stored in the standard FAT12, FAT16 or FAT32 file format.
http://keil.asia/support/man/docs/rlarm/rlarm_fs_flashfs.htm
