11-27-2009 10:55 AM
Thanks for your help and sorry for my late response.
With ctrl+M it works to change the DLL Call, but I still get the same Error.
And I also tried the solution with "Allow debugging", but also there I get still the same error.
Is it possible that you can post the project, which you have changed an is now working ?
bye & thanks
amin
11-30-2009 05:45 PM
Sorry I cannot post a project as the VI which is causing all the problems is part of the advancaed analysis library, which is a locked library.
If you have indeed followed the above directions, you can try using the "rebuild" choice in LabVIEW to make sure your changes take affect. I'm not sure what else to try as I'm not able to reproduce your issue anymore.
