LabVIEW Embedded
Problem with Labview and an ARM Cortex
I have the evaluation version of Keil uVision.
I will try to have the licensed on monday.
Hope it is the solution.
Raphaël
Message 11 of 15
(5,779 Views)
All,
Through working with Keil, we isolated the root cause of this error.
In the evaluation version, the Keil toolchain currently will only allow you to generate code for NI supported targets, viz. Luminary and NXP microcontrollers. If you do see this error with an ST Micro target, your only option is to license the ARM module and then you should be able to develop for any target.
Thank you,
Jaidev
Message Edited by Jaidev on 03-03-2009 03:20 PM
Senior Product Manager
Message 12 of 15
(5,757 Views)
Hi Jaidev,
Thank you for the answer. I will try with the licensed version.
Thanks again.
Raphaël
Message Edité par raphi320 le 03-03-2009 05:41 PM
Message 13 of 15
(5,753 Views)
Hi! I  was do  the same work with you,  Could you  share your experiencewith me.Thanks a lot. My email is  ren12345679@163.com
Message 14 of 15
(5,624 Views)
can anybody help me with my problem?Smiley Frustrated
i need to design and build a autopilot for an aircraft and i need arm microcontroller.
i decided to use labview but as it starts i need a source for doing this with labview and i have questions that i could not find answer for them.
can you help me?
1.can i use labview for such a big work?
2.i need to use windows CE for my arm,can labview support installing and using CE for arm?
3.i want to use cortex for my project but with the start of cortex-m3.are other types supported like cortex-m3?
4.where can i find a book or ebook or sth like this for learning to work with arm?
i reallyneed your help in urgent.
that's very kind of you.
Message 15 of 15
(4,276 Views)
