03-18-2013 05:19 PM
Hello
I have a problem with my lm3s1968 Evaluation Board. I can build and download applications to the device without problems. But the device shows no reaction! Also with labview examples. I use the EK-lm3s8962-USB target, is this the right way for my lm3s1968 device, because of other display size, other ports and so on?
Thanks in advance!
03-20-2013 05:05 AM
Hi
Please see this link http://forums.ni.com/t5/LabVIEW-Embedded/Custom-hardware-and-the-ARM-module/td-p/815817
See question 3. I hope this will help you.
Best Regards
Bernhard
03-20-2013 05:57 AM
Hi Bernhard
I've already saw this post, but it's not really helpful for me. Let me explain that, when I use a simple example like "blinky", I can download this to the device I can start the VI, but nothing is blinking on the device. It's exactly the same with the OLED Display. I think it is something wrong in the configuration, but I can't find the failure.
Best regards Kris
03-20-2013 09:31 AM
Hi
I'm not a specialist for ARM and LabVIEW embedded, but I will do what I can and I hope I will find something in my Database
and I will ask some colleagues from me. You will hear from me soon.
Best regards
Bernhard Rennhofer
03-20-2013 01:49 PM
Hi Kris,
Some of this documentation may be helpful:
ARM Devices Supported by LabVIEW: http://www.ni.com/white-paper/7066/en
Getting Started with the NI LabVIEW Embedded Module for ARM Microcontrollers: http://digital.ni.com/manuals.nsf/websearch/F35870C88A21EDEC86257884005AC97E
LabVIEW Embedded for ARM Porting Guide - Chapter 1: Introduction: http://www.ni.com/white-paper/6994/en
Because you are not using a Tier 1 device the porting guide should be most applicable to you.
03-21-2013 02:24 AM
03-21-2013 03:20 AM
Hi
Follow the first link from Craig and you will see there only 3 Tier 1 devices. There are no more than this 3 Tier 1 devices. I searched for this information in the NI community.
If you want to use a Tier 2 device, so you have to follow link 3 from Craig.
Best regards
Bernhard
