LabVIEW Embedded
PID control
Hi, how do initial gains in pid fpga express vi differ with gains in front panel control? where should I assign pid gains achieved from tuning pid to implement pid controller on fpga target?
Thanks!
(6,172 Views)
Hey ThuZarAung,
Here are some useful documents about the different PID VIs. I would suggest going through these first.
PID (FPGA) Express VI
PID VI (FPGA Module, not express VI)
PID VI (not FPGA)
Using PID on FPGA Targets
LabVIEWTM PID Control Toolkit User Manual (Chapter 3 discusses the different PID VIs)
These should answer most of your questions regarding the differences between them. On a side note, you should not create multiple posts for the same question. If you have additional questions concerning the PID VIs after going through the material above, then please respond on this post.
Alyssa H.
(6,140 Views)
okay! Thank for your valuable suggestion.
(6,130 Views)
I don't still understand pid gains in front panel and gains in configuration box. I attached example vi. Please reply me!Smiley Happy
(6,126 Views)
ThuZarAung,
What specifically do you not understand? Also, the VI you attached has a lot of dependencies and missing SubVIs which makes it difficult to troubleshoot.
Alyssa H.
(6,112 Views)
