LabVIEW Embedded
MCB2300 SD Card Error
These are good news: MCB2300 support files.
However, Jaggs got IO errors, so I don't know if those identified are the "main problems".
1.Of course, the second Open/Replace should be wired to the output of Close File in order to be sure the file opened for writing is closed and then reopened for reading (http://forums.ni.com/ni/board/message?board.id=420&message.id=1455#M1455).
But this is not the case - the generated code does the right thing in this case (open-write-close, open-read-close). Sometimes is no, and fortunately, you don't need an "ultimate solution" here.
2.M:\ is the default drive/path and is concatenated automatically. It would be to easy.
Message 21 of 24
(5,177 Views)
Hello All,
I was still not able to write through the LabVIEW embedded to the SD card.  I always get error 6 or 7.  However, I was able to run the Keil SD card example in uvision and then read/write through the hyper terminal.
Thanks.
Message 22 of 24
(5,156 Views)
Accepted by topic author Jaggs
finally got it solved by using finit(); and small delay functions.  Please see the attached picture.  Thanks NiCB for suggesting it.
Message 23 of 24
(5,141 Views)
This issue has been investigated by NI and the problem could not be reproduced. The VI attached below has been found to work without the need for modification.  If anyone has instructions on how to reproduce this problem, please post them.  If you happen to run into this issue, the above workaround should be a solution.
Message 24 of 24
(4,995 Views)
