06-30-2009 10:50 PM
Hello team,
I am using Labview Embedded for ARM. Could anyone please tell me if I can access the block diagram of functions like LCD initialization. When I go into the block diagram, I am not able to see anything in the block diagram.
Please do let me know how I would be able to look at the block diagram.
Thank you.
07-01-2009
03:49 PM
- last edited on
03-10-2026
08:30 AM
by
Content Cleaner
Hello Herok,
If you right click on the block diagram you will see the functions palette. If you navigate to the "ARM" category, you should be able to locate the LCD VIs that you need.
If you are unable to find these VIs, then perhaps your VI is not part of the ARM target. I suggest you take a look at the ARM getting started guide for a quick tutorial (see link).
07-20-2009 02:54 PM
09-03-2009 06:39 AM
