LabVIEW Embedded
Embedded Partial Compilation
I am looking to integrate LV Embedded with my current VI architecture that communicates using UDP/TCP-IP and was wondering if the embedded module allows using the executable of embedded module to be used inidividually in conjunction with the current architecture. So basically can a piece of the solution be developed in the embedded module and then dropped into a larger project as a binary or something equivalent?
Thank you
Message 1 of 1
(6,072 Views)
