LabVIEW Embedded
Compiler error: dentifier "state" is undefined
It happens that when I use callbacks with global variables and Debug mode non instrumented via EZ-KIT-USB, with generate guard code   I've got this compiler error:
"callback_to_get_button_number.c", line 91: cc0020:  error: identifier "state"
          is undefined
      PDADebugUpdateGlobal(&state, "SPIGlobals.vi", &Buffer_Full__648, BooleanDataType, 0x258);
It doesn´t occur if I use Release mode  in General Build configuration, and the program works fine.
Does anyone know what is worng?
Tanks
(6,486 Views)
Hi alalaguna,
Could you post any simple code that reproduces the problem? Also, which module are you using; the Microprocessor SDK, Embedded Module for ARM Microcontrollers, or Embedded Module for ADI Blackfin Microprocessors? Thanks and have a great one!
(6,459 Views)
Yes sure!
It occurs when I try to write a global variable and with this simple example you can reproduce the problem. I use Adi Blackfin 2.0 and Labview 8.2.1. The bug only appears when you try to debug the aplication via "Non intrusive EZ-KIT" and it does´t with other debug mode nor in "Release mode"
I contacted with my National support engineer, who told me it is being testing by a Blackfin expert, cose they think it could be a bug.
:manwink:
By the way, who can tell me a good book for Labview-Blakfin. I already got "Embedded Signal processing with the Micro Signal Architecture"
Thank you!!.
(6,455 Views)
