LabVIEW Embedded
ARM Luminary TCP debug double precision numbers
I'm working with Labview and a LM3S8962 Luminary evaluation board.
I'm debugging with TCP port and when I use double precision float variables I see some like random numbers on my front panel indicators or on my probe points (i.e. 1.5664325e34.....-12.452244e128) for those variables, but at the same time I'm printing the numbers on the board LCD display and they are shown ok. If I do all the opperations on double precision and then convert the result number to single presicion to display it...then indicators and probes works fine. Also if I do debug with USB ULINK JTAG all works ok on single, double and extended presicion.
Have anybody experienced something like that?
I'm missing some TCP configuration perhaps?
Matthuz
(6,751 Views)
Hi Matthuz,
Is there a way for you to post your code so that we can run the same program?
Kevin S.
(6,735 Views)
Hello Kevin, thank you for your reply.
I'm attaching a little demo to show you what is going on. If I set the debug options to use ULink all works nice, but it doesn't with TCP.
It could be something with the signal generator that I'm using?
(6,728 Views)
Hi Matthuz,
I see what you've pointed out, and I am investigating the issue.  I have noticed that if I create two string outputs on the front panel, which are connected to the same outputs that go to the OLED screen, the correct values are shown on the front panel.  I don't understand why the numeric indicators don't display the same values.  Thank you for bringing this to our attention.
Kevin S.
(6,707 Views)
