LabVIEW Embedded
Can Labview be used for programming of Texas Instruments MSP430 microcontroller for Sensor applications?
Hi aarief,
I believe you used VISA driver to get the values from the USB reciever module through product specific commands.
In my scenario, I need to program, compile and link the microcontroller code from LabVIEW. Is there any way to do that? Or have you heard of any sort of interaction between LabVIEW and IAR ?
Thanks & Regards,
Satish
Message 11 of 16
(6,121 Views)
 I am using ez430rf2500 in my project. I need to use LABVIEW (preferably Signal Express) to read my data on the PC. Please, can someone help me with the VIs required.
Thanks in anticipation.
Nicemoon
Message 12 of 16
(5,965 Views)
i want to ask that how i can configure msp430-rf2500 after installing drivers from visa(device wizard). i m not getting the data coming from the msp430-rf2500 where as i m getting that data in the hyper terminal.Plz guide me!
Message 13 of 16
(5,942 Views)
Sir,
i am using NI WSN 3202 node which is attached with the IEEE802.15.4 ANTENNA , This microcontroller is MSP430 in it. I would like to know that can i be able to access the microcontroller pins with the I2C interface, because the sensor i am using is ADXL345 (ACCELEROMETER SENSOR) and BMP045 (PRESSURE SENSOR) These both sensors are placed on the same chip and giving the digital data and require the I2C interface to connect it.
Please reply as soon as possible
Message 14 of 16
(5,738 Views)
Hi, I also have an MSP430 and I need to get a singal from an accelerometer into labview- Have you found a solution to your problem? Please do let me know.
Aziz
Message 15 of 16
(5,096 Views)
Aziz
Message 16 of 16
(5,095 Views)
