LabVIEW Electrical Power Toolkit
Resampled Waveform Time Delta
I have a seemingly pretty basic question about the data that the electrical power toolkit deals with.  In the example FPGA code the sampled data is re-sampled to convert to constant-angle data.  In the RT code this data is then converted into a waveform (Convert Data to Waveforms VI).  Since a waveform only stores start timestamp, time delta, and data array, does this mean data is converted back into constant time data?  If I read data out of the FPGA in a loop and the frequency drifts will the dt of the waveform change?
(6,489 Views)
Accepted by mbremer
I assume you are looking at the PQ examples.
The resampled data is still constant-angle data, although the data is represented in waveform type with a dt. We do this because we assume the frequency will not change during one data block (~200ms).
If the frequency drifts from block to block, the dt of the resampled waveform will change.
(6,460 Views)
Thanks for the clarification.  Do I need any special consideration for logging blocks to TDMS if the dt value could change?
(6,454 Views)
