LabVIEW Electrical Power Toolkit
Problem sending ni 6002 analog output voltage (0-10V) to control a electronic air pressure regulator.
What is the best way to connect an analog out (NI-6002) an EP-211 (Omega) electronic air pressure regulator (EAPR)? Connecting the output signal directly to the  EAPR won't.  I suspect an impedance miss-match.  I need a solution to correct this problem ASAP.  Any Ideas?
Jim
Message 1 of 1
(4,820 Views)
