LabVIEW Electrical Power Toolkit
FPGA Resampling -- Output timestamp is saturated
I've been debugging an power analyzing station and I discovered the FPGA Resampling vi is returning a resampled element with a (practically speaking) saturated timestamp.  I'm giving it the number of seconds since Jan 1, 1970 as a FXP <+, 64, 32> number (roughly 1,504,198,487) and the Resampled Element cluster always contains a return timestamp of roughly 4,294,967,295.9991xxx.
I feel like I'm missing something simple, but I have no idea what it might be.  Has anyone ever encountered this?
(7,399 Views)
I can't explain the problem but I can explain what I'm doing but it sounds similar.
I take the ns counter from the FPGA timekeeper - convert to seconds to the same representation (unsigned 64,32 FXP) including the UTC correction.
This hasn't given me any timestamp issues under 2015.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(7,371 Views)
Hi James,
I've included a small project (including bitfile) that reproduces what I'm seeing.  Here's the FPGA block diagram:
The green rectangles highlight locations where I can monitor the timestamp sent by the Timekeeper.  The red rectangle is where I get the saturated timestamp.
My RT block diagram is extremely simple:
The green rectangles show where I read the Timekeeper and convert it to a readable date and update the Timekeeper with RT time.
This is what the RT front panel look like when I run it:
The rectangles here correlate to the green and red rectangles on the two block diagrams.  As you can see, the timestamp returned by the Resample vi is very nearly saturated.
Can you please try the code on your system and see if you get the same behavior?  This is with LabVIEW 2015 sp1 and an sbRIO-9626 running LV Real-Time 15.0.1 from Feb 2016 (v15.5).  For testing, I'm downloading the FPGA code to the FPGA then running the RT code interactively.
(7,362 Views)
Hi Daklu,
All my systems are tied up in a long term test right now but that will finish in a couple of days and I can give it a go then.
Cheers,
James
James Mc
(7,346 Views)
James,
Have you had a chance to try out this code and see if you get saturated timestamps as well?
(7,274 Views)
Hey Daklu,
Managed to give it a go today. On a cRIO-9024 (9113 chassis) it is showing no problem. This is under 2015 SP1f7.
Only thing I've done is added a new target to the project and dragged over the VIs.
Not entirely sure what that means!
James Mc
(7,254 Views)
