Thx for this presentation. I had not recognizes that starting with 8.2 one can load & unload DLLs. And the configurable loading feature was also unrecognized by me. Another reason to change the horses...
Watch out the unloading of DLLs doesn't always work as one would like. At least in older LabVIEW versions, a once loaded DLL is only unloaded when a new DLL name is loaded into a CLN. According to the documentation an empty path should unload the DLL too, but that did not always work. Not sure when and if they fixed that.
You know, my workhorse projects are still in LV711 and I always shied away from updating when everything I needed is there with 711. This could have been a reason, but ... - good to know of such unexpected behaviour.
I'll try to dynamically load the CIN-callers, maybe this works.
