Purpose
The LabVIEW Container is a new way to pass data around on your block diagram. It combines the strengths of the array with the strengths of the cluster. NOTE: this is an early release! Containers are still in development.
Check out this short, 5 minute video.
Description
Let me first start off by giving some motivation. I created the Container to combine the strengths of the array and cluster.
Array Strengths
Array Weaknesses
Cluster Strengths
Cluster Weaknesses
In summary, the LabVIEW container allows you to store named data of ANY type in hierarchical relationships. The strength of the Container is its flexibility at run time. You can change the hierarchy or change what data you're accessing programmatically, almost as if you could programmatically edit or interact with a cluster. The API below describes how you interact with Containers.
Introduction to the Container API
I've created an API so that you can easily and intuitively construct, compose, access, display and clean up your containers. Below is a brief example of the most basic usage of the API:
Construct
The first step is to bring a Container into existence and give it a name with the Create.vi. Think of this as dropping an empty cluster constant on the block diagram.
Compose
To create a hierarchy, use the "Add Child to Container.vi". This is similar to adding a cluster to a cluster, or (if it were possible) putting an array into an array.
Access
The Get \ Set Attribute VIs are designed to allow adding or retrieving data of ANY type from a Container. This is like the bundle and unbundle by name. But, whereas the bundle \ unbundle by name is static on the block diagram. the Get \ Set takes in the name of the attribute that you'd like to interact with similar to the Index Array array function.
Display
Because the container is arranged in a very predictable way, it can be presented through many different views. I've implemented a tree view that displays the Container as a tree, which mirrors the "One Parent - Many Children" model of the Container design. The tree below is a display of the "Top Level" container from the block diagram above.
Destroy
In order to prevent memory leaks, call Destroy.vi. This releases the Container and all of its children recursively.
Complete API
Here is a palette view of the complete API. This palette is installed from the VI Package attached below. The most common operations are promoted to the top. Namely, Create \ Destroy, Set \ Get Attribute, Add \ Get Child, and properties. The more advanced functions are located in the Utility folder.
Here are all of the API VIs:
API Explanation
A few of the API VIs warrant some explanation.
Get Attribute
The Get Attribute VI returns a value by its name. I designed this VI to be polymorphic for many of the common data types, so that you won't have to cast from a variant to your desired data type.
Get Child Container(s)
The Get Container(s) VI is a polymorphic VI allowing you to get 1, N, or All (non recursive) contained containers.
Cluster To Container
The cluster has many advantages, one of which is the ability to design your datatype on the block diagram. There is a visual representation on the block diagram of your cluster vs. the Container, which has no visual representation at edit time. So I created this VI to create a Container hierarchy from a cluster:
Here's an example of the Cluster to Container:
Extending the functionality of the Container
The Container is a class based implementation "under the hood". The fact that it is classed based is hidden away by the API. The Container presents no barrier to usage if you're unfamiliar with LV Object Orient Programming. However, if you are familiar with LV Object Oriented Programming you create your own type of Container based on the work I've already done. I've created two child classes that inherit from Container named "VI" and "Control" as examples of how to override the API.
"Back end" Implementation
I wanted to spend a few paragraphs describing the implementation of the Containers. The Container fundamentally consists of three objects of the Container Intermediate Representation (CIR) class.
The three objects are intended to house key \ value pairs of three types:
1. Public Attributes
2. Private Attributes
3. Children
The public attributes are those edited by using the Get \ Set Attributes API. The Private Attributes are used for information that could "muddy" the contents of the Container. For example, the "Container type" is a Private Attribute. The Children object is meant to store the references to the children contained within the parent Container.
I chose this implementation because I wanted to allow a Container to have an attribute that has the same name as a child Container. I also wanted an "easy" system for distinguishing between an attribute and a Container.
The CIR itself simply defines an interface between the Container and the organizational mechanisim that implements the key \ value lookup table. I've chosen to implement the CIR as a variant. The variant has the ability to store meta data about a value using the "Get Attribute" and "Set Attribute" primitives. That meta data just so happens to look and feel like key \ value pairs. So I've recycled the variant to act as the organizational mechanism. However, the CIR is overrideable allowing you to use other mechanisms such as XML or perhaps a data base. Using these other representations may allow easier complex querying, etc.
Getting the Containers Installed
You'll find the Containers VI Package attached below. The Container depends on the AQ Character Lineator (attached below) and the ni_lib_class_retrieval (attached below).
Lastly you'll need the free Open G toolkit which can be installed from the VI Package manager. Upon installation you'll find the Containers on the palette under "Functions". The install location is ..\vi.lib\_ApplicationTools\Containers where you will find 6 API demos.
I've also included a small test suite accessible from the Container.lvclass at ..\vi.lib\_ApplicationTools\Containers\Container\Container.lvclass. Opening the class you'll find the test suite at SubVIs \ Not on palette>>Tests>>TestSuite.vi.
I've created a custom probe which can be found at ..\vi.lib\_ApplicationTools\Containers\Container\SubVIs\Custom Probes\ContainerTreeProbe_DVR.vi
Future Efforts
There is still a fair amount of work to be done to polish things up. There are many "todo" comments and VI Documentation needs, etc. So this is a work in progress. But I wanted to get it out there to start getting feedback. Please feel free to add your comments and requests and how you're using it.
New features
1.0.1.39
Fixed how I call into the serializer. Now serialization works!
I've added a "tree" vi to the pallette that contains all of the API vis.
2.0.0.4
Fixed serialization of nested containers. Moved the source from vi.lib to user.lib. Source is still compiled in LabVIEW 2014.
2.1.0-3
Including build instructions
Minor bug fixes
reorganized zip file to include instructions and dependencies
Known Issues
1.0.1.40 - Deserialization is functional but under some cricumstances can be very slow. I'm still characterizing the bug.
REQUIRES LATEST vi package manager
1.0.1.41 - Serialization \ Deserialization was broken for nested containers. I've made a fix, added a test to the test suite, and reved up the major version to 2.0. Please be aware I've moved the location of the container from vi.lib to user.lib as this is not a National Instruments product. You'll find it in user.lib\_Cirrus Logic\LabVIEW Container\Source.
Nice work, Chris! I'm considering a tree approach on an upcoming job which will involve a test executive. While I've used both LabVIEW and TestStand extensively, I'm leaning toward toward pure G this time. Have you noodled on this idea at all? I could imagine each test step type being represented as a cluster.
Hi Chris,
This certainly looks interesting. Do you have any preliminary data on how this approach stacks up in terms of performance against something like a variant attribute based associative array? Do you have any plans to support being able to stuff non-cluster datatypes (maybe generic LV Objects) into the containers? Another thing I am curious about is if there is planned to be any built in methods for diff or merge of two containers?
Hey thanks LabBEAN! I've considered applications very similiar to what you're proposing. Instead of a test step type, I was considering a Measurement configuration that I would pass to a "DAQ engine". That is, I want to create a subVI that takes in a container of DAQ configurations. Those configurations could be AI, AO, DI, DO etc. The individual containers would represent all of the parmeters for each of the "tasks" that I want the engine to execute. The beauty is the reuse of a DAQ engine. I want to be able to drop my DAQ engine into any application is it "just knows" how to handle the AI container or the DI container, similar to your test executive handeling a container of test parameters.
I like the idea of an engine and I think containers could help enable such an idea.
Thanks scrook!
So I realized I need to rework some of my wording in the document. You can already put ANYTHING into a container (including a class). It does NOT have to be a cluster. The API vi "Convert Cluster to Container" is designed to create a container based on a cluster.
An area for development would be representing the "anything" in the tree. I've handled many types... but not all. For example and N Dimension array is something I don't handle nor the contents of a class.
I had considered providing a vi that could be overridden for merge and diffing two containers. I think Diff could be "easier" although still complicated. Merge is a complicated task though. But it has crossed my mind and should time permit, those are on my radar.
I have some data comparing the container (before I abstracted it into the Container Intermediate Representation layer). I varied the number of key value pairs from 1 to 20000 for reading and writing. The results are below. I need to rerun these test after introducing the abstraction layer though.
Hi Chris,
It's great that more 'squishy storage' datatypes are making an apperance in LabVIEW.
In our company we make pretty heavy use of an associative array class in LVOOP. I put together a whitepaper on that a couple years ago (though we did switch the under the hood to variant attribute lookups for speed).
The way I handled dealing with 'anything' was an everything is a string model internal to the class but the 'getters' and 'setters' would be polymorphic and implement different types. You lose some memory (and pay some unmartialing penalty) when you're unflattening complex stuff like LV Objects from string but it's still pretty fast.
If you have an interest it is located here: https://decibel.ni.com/content/docs/DOC-28267
Great job, that could find a use case for our application A few remarks:
<I don't understand your requirement of being able to have an attribute and a container of the same name, how can it be useful?>
I like this feature as it allows us to create sub-containers and attributes programmatically with no regard as to whether there will be name collisions.
Hey Charles,
First off thanks for checking it out man!
Seriously, thanks for the interest!
This will fill a gap that has been bugging me for a long time. I have deal with the pros and con of Arrays and Clusters and choose one. Kudos!
Hey DanyAllard,
So that's just a tad embarassing
. Problem fixed. I posted 1.0.1.34. Thanks man!
This is an invaluable tool, and the refinement going on here exemplifies the value of the Community. Thanks Chris. My thoughts and suggestions:
Is it possible to package separately the dependencies on AQ Character Lineator? This dependency feels like a lot of unnessary baggage (only speaking for myself).
Don't stress about the tree view. Objects and N Dimensional arrays would be tricky, and I can't envision the use-case for showing a tree of datatypes and values to the user anyway.
- Michael
Great catch! I've added it back in and rearranged the palette in 1.0.1.35. Thanks again Dany!
I agree with you MIchael. I would like to lower the overhead for depending on AQ Character Lineator. I'll take a look into that.
This is an innovative data storage tool that overcomes the limitations of using arrays and clusters. And more importantly, it allows us to edit data hierarchy programmatically.![]()
Really nice job ![]()
Flo
Check the Print Container API out at https://decibel.ni.com/content/people/Chuan/blog/2014/06/27/print-container-api .
It can recursively print container hierarchy into .txt files.
I do not find this valuable. Sorry.
What is wrong with using the Set and Get Variant attributes? I'm sure the performance of a single primative must be better then your library.
As for displaying it I would just use the Variant Probe.
http://lavag.org/topic/13748-cr-variant-probe/
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
I think that variants are great if you don't need a hierarchy. You could thing of that basically as a dynamic cluster, without the ability to embed a cluster in a cluster. But there are many reasons why it can be very beneficial to create a hierarchy of clusters. The containers allows the embed of a container in a container and the ability to navigate by name.
Why can't a variant have a attribute that is a variant? That makes your hierarchy. This still has navigation by name.
Very true, but what if you were given a variant and wanted to know what variant it came from? It is easy to navigate down into the variant table but not easy to navigate up. That's one of the abilities of my containers.
If I wanted to know where a variant came from, I wouldn't be passing around the variant I would be passing around the variant's, variant. If you got a container you also can't know where it came from, unless you pass around the container that contains the container.
Ahhhh.... that's the trick. I embed in each container a reference to the container that contains it. It is a "two way linked list" like behavior.
Okay you got me there, that is a benefit. I can't think of a time I would want to do that but it is something variants can't do without extra work.
Hi Chris,
I posted some questions and suggestions at your forum post last month: http://forums.ni.com/t5/LabVIEW/The-LabVIEW-Container/td-p/2838928
Could you please have a look?
Hi Chris: I checked this out based on your comment from the LV 2014 new features page from yesterday. Your library seems really nice but like Hooovahh, I don't really need hierarchical data. I don't even really need named data. What I do need are performant associative arrays.
Like many others, I am using variant attributes, but they would work so much better if I could make polymorphic wrappers for them. Just think how much more useful queues and notifiers are, now that they are primitives rather than VIs which only handle strings (which was how they debuted).
What I would love to see is something that is almost exactly like the queue feature, but instead of accessing items in a specific order, they would be accessed by a key, which could be any labview data type. A huge bonus would be to be able to access a single element with an inplace memory structure so that a read/modify/write operation could be done safely and efficiently. Sure some of that stuff can be implemented with existing LV primitives, but now that we're in the era of "big data", it's long past time when this should have been added to the language.
@jdunham: There's no reason why performant associative arrays can't coexist with hierarchical trees, right?
I, too, would like easy polymorphism that adapts to any type we throw at it. But I get the impression that such a feature would need to be implemented in the LabVIEW kernel itself (or through XNode black arts) -- something only LabVIEW R&D can touch. I'm guessing that non-R&D NI employees like Chris would be restricted to the same set of tools available to you and I.
Rather than discourage him, let's welcome all efforts to give us better tools ![]()
I love the idea, i have a similar approach, but i think i like your implementation better. Going to spend some time with this to if i can use it.
Thanks!
Hi I have been trying this for a project in LV2014 but as soon as I put any VI on the block diagram I get a broken main VI with all sort of errors. Am i doig something wrong? Instaled the latest versions. Thanks for your help
I'm guessing that you've missed a dependency. The list of dependencies above should still work. Make sure you have them installed and give it another shot.
I recommend you re-evaluate the benchmarking of this code.
Looking at it myself I disabled debugging, put a single timer around the array of attribute operations as opposed to for each iteration and perhaps more importantly made sure both parts of the code were doing the same work - actually returning values.
If you actually USE the values returned when reading (The native Variant already presents the correct value for you) this means adding a Variant to Data after the Container read. I then average the returned values to make sure LabVIEW cannot optimise anything away. I see the read speed being factor 4-5 slower than variant with wwrite speed being around 2 times slower.
Bear in mind I have NOT disabled debugging in ALL VIs in the project, just the benchmark VIs.
I would also recommend not setting sub-vis to Time critical priority. That's not likely to go down well in real code. Debugging and priority don't seem to change much on my results though.
Hi Chris,
concerning your "Known Issues": - have a look at my latest comment here: https://decibel.ni.com/content/docs/DOC-24015#/?page=4
cheers, Benjamin
So I'm getting the chance to user my containers for continuous integration. The use case is i have a complicated hierarchy of VI Packages. I want to call "build" on one partiuclar VI Package and my build system be able to build a VIPs dependencies if there are unbuilt changes or update my VIPs dependencies to the latest version of a sub VIP. To do that I have to be able to construct the tree of dependencies which will involve performing searches, copies, and moves. I also want to have information at each node, like vip name, version or anything else... SOUNDS LIKE A JOB FOR CONTAINERS!
Hi Chris,
i tryed to build a ppl using containers. Build was unsuccessfull cause of a missing file in Class Retrieval.lvlib:
Source: P:\alsmith\SolutionsEngineeringNI\AQ Character Lineator\Class Retrieval\.trunk\Name to Path Conversion\NTP Conversion.mnu
i can solve this for my own, but it should be fixed in the vip.
regards
Thomas
Hello Chris,
There are some broken VIs in Container.lvclass. What am I supposed to do to fix this?
I have installed open G toolkit and all three vip packages.
Is this container class part of LabVIEW, or the open g code?
...after all, He's not a tame lion...
Which VIs are you seeing broken? I've seen that *sometimes* "something happens" that causes the VIs to break without errors being listed. To solve the problem, I usually uninstall and reinstall the containers package. Give that a shot.
Hey Mike
The container is netiher a part of LabVIEW nor the OpenG code. At this point it lives on its own.
Hello Chris,
First of all thanks for this nice job.
I have an issues on the container Serveral Vi broken as Property Node.I am still able to use the API but I do not understand why this VI is Broken.
Do you have an Idea?
Here VIs Broken
Sam
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
Hi @ Samuel,
Thanks man! That VI is broken because, on the palette, the vi is set to "Place VI Contents". So everything should be ok. I'm able to open any of the api demo vis in the "LabVIEW Container\Source" directory.
Is this project still active?
I think I have followed the download and installation steps correctly, but cannot find any of the serialize / deserialize classes, ctls or vis.
Have I missed a step?
A.K.
