LabVIEW Communications System Design Suite
Tell me how can I integrate PTC ceramic Air heater
Tell me how can I integrate PTC air ceramic heater in LabVIEW through LINX.
(688 Views)
You need to define all terms such as "integrate" and "through". LabVIEW and LINX are both software components. Please add a few paragraphs describing the hardware you have and what you are trying to achieve (remote on/off? PID control? scheduling?).
It is not clear why you are posting in the "LabVIEW communications system design suite", because this is probably not the correct software for this.
(665 Views)
PTC ceramic air heater runs on mains AC (consumer heaters) and you can control it through electromechanical relays or SSR, you need to appropriately choose the relay rating higher than the heater power consumption. Now, you can connect the relay to Arduino to a digital output, now use the LINX toolkit to set the digital pin state to high or low to control the relay which in turn controls the heater.
Santhosh
Soliton Technologies
(631 Views)
