LabVIEW Communications System Design Suite
Sphere decoder
 I want to build Sphere Decoder in Labview communication suite, I have the matlab code for sphere decoder. If I use the math file, would that decrease the speed of my system? if yes, then is there any similar example to sphere decoder that I can use to help to build my sphere decoder block?
Many thanks,
Waseem
(4,683 Views)
Hello Waseem90,
If you have the matlab code and it runs well, then using the MathScript Node in LabVIEW Communications should not slow down your system. Please note that how the script is written will affect this. If the script is optimized then LabVIEW Communications should run it without any difficulties.
If you do face issues return to this forum and I can open up the issue again.
Jarmo Levo
(4,663 Views)
Thanks for your answer. I have the code for sphere decoder but it doesn't run in the m. file of labview. is there any block for sphere decoder or similar decoder?
Many thanks,
Waseem
(4,601 Views)
