LabVIEW Communications System Design Suite
Monitoring spectrum with USRP 2920
hello
i see all examples about monitoring spectrum
but nothing is close to my  desired app cause
as example  https://decibel.ni.com/content/docs/DOC-40721
it use one input " carrier " and then show spectrum
i want to put start and stop frequency within instantenous bandwidth of USRP 2920
and monitor spectrum within desierd band
i want to show signals at thier real carriers not baseband signal after demodulation
thank you
(4,940 Views)
Accepted by topic author M_Shaban
Can you explain a little more about your intended application usage? What frequency range are you trying to monitor? As well, can you explain why you need to "show signals at their real carriers and not baseband"? The USRP 2920 has only 40 MHz of instantaneous bandwidth (and only 20 MHz at 16 bit resolution) so unless your "real" signal sat in baseband already (i.e. below 40 MHz) you would be stitching together the spectrum needed to get a wideband acquisition and it would not be instantaneous anymore.
John Gentile
Applications Engineering
(4,911 Views)
Hello
I have de attached error
regards
Leo
(4,875 Views)
My device show that
Coerced IQ rate for 2920 is only 33.33 Miga HZ
Its not stable at this higher IQ rates
And it have very slow response near 30
Thank you for ur help i will try with another NI device
Thank you again for your time 😌😌😌
(4,868 Views)
Leonardo
I think i face this problem before but i don't remember at this moment what is fault
If you can attach your VI or share ur block diagram
I will help you as i can 😊
(4,860 Views)
