LabVIEW Communications System Design Suite
Simulate two USRPs
I am designing a communication system for running in multistation mode. At the moment, I am able to run the FPGA-VI-code in simulation mode using a "loopback PHY". Now I would like to simulate the behaviour of multiple stations communicating to each other using a  "shared medium". Which would be the best procedure here?
(3,288 Views)
Hi curopa,
the simulation mode you run your FPGA code in is a mode to test if your code can run on an FPGA in general. It is not a replacement for a hardware. This is why the simulation mode only runs with simulated input and outout signals like sinewaves the driver generates. It is not possible to connect two simulated FPGA simulations and run them with "connected" inputs.
Best,
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(3,145 Views)
