LabVIEW Communications System Design Suite
Baud rate doesn't change when "view code"
Hi there,
I set up the UART in block view and change the baud rate from "9600" to "115200" . Howeve, when "view code", I found the baud rate was not switched accordingly. Anything I missed or this is a known issue? Any input is highly appreciated.
Screenshots are attached.
(2,536 Views)
Hi Colinpro,
What you have highlighted is the name of the input going into the VISA serial function. Try writing this to an indicator to this property and it should give you the correct value that you are inputting.
Adena L.
Technical Support Engineer
(2,510 Views)
