06-01-2017 11:29 PM
Hello.
I have a simple problem dealing with all the day. I really appreciate if you can help me out. Please see the attached picture. I am trying to implement a PAM RX. I need to connect output of MT Generate PAM System Parameters to input of MT Map Bits to PAM Symbols. But I dont know how to make the data compatible.
06-02-2017 12:40 AM
I figured I need to use unbundle cluster by name. I can not find it in labview communication!!!!!!! It is in labview under cluster pallet but not in labview communication!!!
06-02-2017 08:27 AM
Hello Ferdoon,
In Comms and NXG, you use the Cluster properties node to unbundle by name:
I apologize fort the confusion.
Gerardo
06-02-2017 11:02 AM
Thank you.
