LabVIEW Communications System Design Suite
LABVIEW FPGA Does not exist
I did it. It ran for one time and returns the error another time!
I number of times from fresh project too by creating new project and un touching it. No help!
Same error for completely new project too!
Message 11 of 20
(3,845 Views)
Hello Wired_,
If the error is occurring on a new project that was generated from the template, I believe that the problem is with your installation.
What version of LabVIEW Communications are you using?
Can you try to repair the installation?
If you are using 1.1, I can save a copy of a new template project on my computer and upload it for you to try. I don't think this will provide us with any good information.  Repairing is our best option right now, in my opinion.
Thomas C.
FlexRIO Product Support Engineer
Message 12 of 20
(3,828 Views)
Hi!
I am using 1.0 as of now which came with my purchase.
Can you point out how to repair?
I tried reinstalling the communication suite using the software package I had. But it did not install since it was already present.
Next I manually deleted the folder containing Labview Communication suite from National Intruments folder. Now I cannot reinstall!
Can you provide leads to move ahead with the repair with the package I have given that I am not able to install since it's assuming that it's alreadt there.
If by any mean I can uninstall then it would be easy but  did not see it in programs list!
Message 13 of 20
(3,814 Views)
Hey Wired
Thanks for making the new post.  Check out my links there.
Thomas C.
Message 14 of 20
(3,799 Views)
To clear doubtsi reinstallled things. But still the error for Tx Stream 0 comes!
To surprise, if I select RF1 the code runs!
To make matter worse sometimes randomly, this FPGA compatibility error is also coming today!
Message 15 of 20
(3,787 Views)
Hello Wired_,
I was able to create the same project and upload it here:
ftp://ftp.ni.com/outgoing/SISO.zip
Can you try to run it?
Thomas C.
Message 16 of 20
(3,765 Views)
Hi!
Thanks for file. Can you repost it? I cannot access it as of now.
As latest report the design works with choosing RF1 chain but now with RF0 chain.
Message 17 of 20
(3,719 Views)
Hello Wired,
I re-uploaded the SISO.zip file.  This will be available on the NI FTP for the next 24 hours.
Thomas C.
Message 18 of 20
(3,711 Views)
Hi!
Last time I tried with the design at RF 1 it did work. RF 0 was still problamatic. To surprise RF1 is also not working now.
Message 19 of 20
(3,534 Views)
Forum Note:
This thread has been continued here:
http://forums.ni.com/t5/LabVIEW-Communications-System/Configuration-Library-Signature-on-host-does-n...
Thomas C.
Message 20 of 20
(3,507 Views)
