LabVIEW Communications System Design Suite
How to synchronized the Tx and Rx
Hi all,
I am trying to build a radar system in LabVIEW Communication, so I need to synchronized the Tx and Rx in one USRP 2900. I have already build a synchronization system (attached below), and both the "Reference Frequency Source" and "Timebase Clock Source" were set to "internal" ,but the error "niUSRP Initiate.gvi<ERR>A stream command was issued in the past" was shown and it could not turn on the Rx. Does anyone  know how to solve this problem?
Best regards.
Olivia
(4,080 Views)
Accepted by topic author yh10915
Hi yh10915,
I have come across an error code, I believe this could potentially be the source of your issue:
Error -107411864 "A stream command was issued in the past" occurs when you set Timebase Clock Source to PpsIn and do not provide a timebase clock source to the PPS IN port.
If you set Timebase Clock Source to PpsIn and do not provide a timebase clock source to PPS IN, the USRP device will revert back to its internal timebase clock source. This may result in error -1074118649 "A stream command was issued in the past."
Workaround: Provide a timebase clock source to the PPS IN port.
Kind regards,
Matthew Fergusson
Applications Engineering
(4,016 Views)
Hi Matthew Fergusson,
Thanks for your reply.
I used dual function generator to output same PPSin and REFin into two USRP. And it works very well in Labview, but when I try to run it in Labview Communication, the error of 'A stream command was issued in the past' was shown.
Best regards.
Olivia
(3,990 Views)
