LabVIEW Communications System Design Suite
[Feature request] MathScript compatibility
I prepared a script that runs just fine in Matlab. However, when I try using it in a MathScript node, there are actually some syntax errors. In this case, "rc" is my custom function that returns the Raised Cosine. See attachement.
I hope this helps improve the compatibility of the syntax.
Also, you might want to add *.m to the list of valid extensions that can be uploaded as an attachment in this forum.
Nicola
(8,765 Views)
 Some functions and properties in MATLAB can not be used in MathScript RT Module.
The following page lists all the supported functions.
http://zone.ni.com/reference/en-XX/help/373123C-01/
(8,748 Views)
Hi ,
I have consulted the link that you have provided concerning the list of functions Mathscript module and I found the function "erfc_inv" that I actually need in my project but it doesn"t seem to be recognized in labview communications design suite.What should I do ?
(7,247 Views)
Hi emnajaoua,
Actually you can find the supported M functions here in the manual. I didn't see that particular function through a brief look but you may want to verify. I did find it available in the supported C functions though.
David C
(7,236 Views)
Thank you for your help.I will turn it to C node than.
Best Regards,
Emna.
(7,225 Views)
Is there a function or VI that can compute for me the inverse of a function like "erfc".because I need erfc_inv not just erfc.
(7,223 Views)
Hi DECONN,
Do you know a way to initialize an array in C node without knowing its actual size or how to plot an array as an output from the C node.
Thanks in advance.
Emna,
(7,219 Views)
