LabVIEW Communications System Design Suite
2x2 MIMO by using 2 USRP2922
Hi Everyone,
I have 2 USRP-2922. I want to make 2x2 MIMO system design but when I look some works done in MIMO for instance 8x8, 4x4,6x6 it seemingly not possible.Is it true or false?
Thx...
Message 1 of 8
(6,999 Views)
Hi mcan,
I'm not exactly sure what you're asking, but if it's can you do 2x2 MIMO with 2922's, then absolutely yes. Here's a white paper that's specifically geared at 2x2 MIMO: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2rKCAQ&l=en-US
Cason
NI Applications Engr.
Cassandra Longley
Senior Technical Support Engineer - FlexRIO, High Speed Serial and VRTS
Message 2 of 8
(6,971 Views)
I want to make 2x2 MIMO by using 2 USRP-2922.I think it is not possible because 8x8 MIMO system design paper use 16 USRP-2920 kit. Indeed when I tried to first example in the white paper, front panel of the Tx and Rx part need 2 usrp separetely.
Message 3 of 8
(6,967 Views)
Hi mcan06
No it's not possible to do 2x2 MIMO with 2 2922's. USRP 2922 has one Tx/Rx and one Rx. If you had a different USRP, such as USRP RIO, you can reduce the number of the hardware used. But USRP RIO is much more powerful, hence more $ than 2922.
Product Marketing Manager
FShirai
Message 4 of 8
(6,962 Views)
Actually I have two USRP 2922. When I connect two USRP by using MIMO expansion cable, I have 2 Tx and 2 Rx
Message 5 of 8
(6,960 Views)
the picture of what I have and also have 1 MIMO expansion cable
Message 6 of 8
(6,939 Views)
You are right. That should work. The diagrams are a bit misleading on the white papers.
Cheers,
FShirai
Message 7 of 8
(6,936 Views)
I think this document said that is possible to make 2x2 by using 2 USRP-2922, but actually I haven't implemented yet.
https://www.ettus.com/content/files/kb/mimo_and_sync_with_usrp.pdf
Message 8 of 8
(6,893 Views)
