02-14-2018 04:46 AM
Hi Everyone,
I have 2 USRP-2922. I want to make 2x2 MIMO system design but when I look some works done in MIMO for instance 8x8, 4x4,6x6 it seemingly not possible.Is it true or false?
Thx...
02-15-2018 12:41 PM - last edited on 01-11-2024 10:25 PM by migration-bot
Hi mcan,
I'm not exactly sure what you're asking, but if it's can you do 2x2 MIMO with 2922's, then absolutely yes. Here's a white paper that's specifically geared at 2x2 MIMO: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2rKCAQ&l=en-US
Cason
NI Applications Engr.
02-15-2018 01:08 PM
I want to make 2x2 MIMO by using 2 USRP-2922.I think it is not possible because 8x8 MIMO system design paper use 16 USRP-2920 kit. Indeed when I tried to first example in the white paper, front panel of the Tx and Rx part need 2 usrp separetely.
02-15-2018 02:10 PM - last edited on 01-11-2024 10:26 PM by migration-bot
02-15-2018 02:50 PM - edited 02-15-2018 02:51 PM
Actually I have two USRP 2922. When I connect two USRP by using MIMO expansion cable, I have 2 Tx and 2 Rx
02-16-2018 06:10 AM
the picture of what I have and also have 1 MIMO expansion cable
02-16-2018 08:16 AM
You are right. That should work. The diagrams are a bit misleading on the white papers.
Cheers,
FShirai
02-22-2018 02:53 AM
I think this document said that is possible to make 2x2 by using 2 USRP-2922, but actually I haven't implemented yet.
https://www.ettus.com/content/files/kb/mimo_and_sync_with_usrp.pdf
