Online shopping is currently unavailable.
Please contact us for help or try again later.
LabVIEW Code Questions
activation code
We are a rookie FRC team and can not seem to get the LabView game tools to load.  It says that the password from FRC is invalid, some people in other forums said to use the SN #, but all I see is a P/N #.  Can you please help - we are seriously lost in this process.
(5,384 Views)
The serial number is included in the portal the lead mentors have access to.  They should be able to login to see what vouchers are available for your team.  Other mentors can login but won't have access to the voucher.
The number contained in the vouchers is your SN which should allow you to activate.
(5,356 Views)
Thanks for your response -
This is the coach and the voucher/password is not being accepted when prompted by the NI software install.
(5,321 Views)
Can you share a screenshot of what you see in NI License Manager?
It'll also help to see what error you're getting when you bring your mouse over the warning text (it will pop up an explanation).
(5,314 Views)
The licensing dialog supports a number of different licensing credentials. Most likely, you are presented with the one that takes 17 digits or something like that. If you click on the drop-down, I think serial number is the one that fits your FRC #. That number should look similar to BxxPxxxxx, where x is a digit.
(4,928 Views)
