LabVIEW Channel Wires
Channel Wire Reference Leak
I am elaborating a channel wire tag to stop parallel loop to make my code simpler as compared to notifier. However, I found a reference leak when using desktop execution trace toolkit. Any idea if I make any mistake in the program?
I am using this simple program to test.
Here is the message from Desktop Execution trace toolkit:
676413 21:40:14.1657490 Tag-bool.lvlib:))Channel.vi:7310015 Reference Leak 0 1 VI Unknown Leak : 0x18067E78
Details: Unknown Leak : 0x18067E78
Call Chain:
-- Tag-bool.lvlib:))Channel.vi:7310015
-- Tag-bool.lvlib:Instantiate.vi:4380002
-- Untitled 3
VI Path: C:\Users\Engha\Documents\LabVIEW Data\2018(32-bit)\ExtraVILib\ChannelInstances\Tag-bool\))Channel.vi
Thread ID: 0 --- CPU ID: 1
Thanks & Regards,
Irfan
(CLD)
https://haliatech.com/
(10,470 Views)
Accepted by topic author irfanabid
Your program is correct, and there is a reference leak-- we create a reference internally in order to enable probing the channel and we neglected to close it.  The fix will be in LabVIEW 2020.  Thanks for spotting this and alerting us to it.
--Jeff
(10,431 Views)
@jkodosky wrote:
....  The fix will be in LabVIEW 2020. ...
--Jeff
There is only one person that has the intestinal fortitude to predict which version a bug will be fixed in.
Smiley Wink
Ben
(10,426 Views)
Question: is this an actual reference leak or just a nominal one?  In other words, could one construct code where an unlimited number of such references are generated?  Because not everything called a leak by the trace toolkit is actually a leak.
(10,411 Views)
--Jeff
Welcome to Agile development!
(10,368 Views)
Merely a nominal leak. In fact, it isn't exactly a leak... we are leaking "not a refnum". What's being reported as a leak is the cleanup proc is running to cleanup what is *potentially* a refnum, but turns out not to be.
No, you cannot construct an infinite leak with this.
(10,353 Views)
I wish the trace toolkit labelled things potential reference leaks.
(10,330 Views)
