LabVIEW Architects Forum
Tuesday, November 15 is our next meeting. Call for presentations.
With a tie of 8 likes each, we have two presenters for the next meeting:
Presenter: Allen Smith
Title: Unfunded Liabilities:  How Poor Package Design Drives Technical Debt, and What You Can Do About It
Description: As software applications grow in size and complexity, they require a larger unit of organization than the VI, class, or library.  Organizing our software into packages is important to long term success, but package design is an oft-overlooked aspect of system development in the LabVIEW community.  The result can be an application that is increasingly resistant to change, or even prematurely obsolete.  Come to this session to learn the principles of good package design, and some metrics and tools you can use to guide your own development.
Presenter: Chris Cilino
Title: Automating Build Processes for Source Based on VIPM
Description: The process of moving from "Code and Fix" to professional software development usually entails continuous integration of some sort. At Cirrus Logic, we are in the middle of that evolution. To take us to the next level, I've designed a prototype build system that automates the creation of VIPs from libraries of code that are hierarchical in nature. I intend on publishing this system to the community at some point in the future and will design it to be extensible so that other distributions, such as exes, dlls, llbs, can be created.
We will be updating register information, in the following days.
The presentations that didn't make it, will be copied on the next call for presentations for our next meeting.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 11 of 12
(1,502 Views)
Meeting details found here: https://decibel.ni.com/content/docs/DOC-49203
Message 12 of 12
(1,502 Views)
