Note: Scripting is include with LabVIEW 2010 - 2013. No extra download or activation is needed. Simply enable in your Tools>>Options Dialog.
VI Scripting enables users to write a LabVIEW program that can generate and inspect LabVIEW code. It exposes many additional VI Server classes, properties, and methods. It allows you to create new VIs, Front Panel controls, Block Diagram objects and wires as well as traverse diagram object hierarchies and modify code.
For Windows: Download the Windows installer from this page (XP or Vista/7). 32- and 64-bit versions refer to your LabVIEW version, not your OS.
You need to activate VI Scripting before the feature is available in LabVIEW.
For Mac/Linux: No activation is required (disregard steps 1-5 from above), download the Mac/Linux installer from the following download page.
Getting Started documentation is located at the following path ...\labview\manuals\VI Scripting Getting Started.pdf
Examples are located at the following path: ...\labview\examples\VIScripting
Technical Support
As this is an "NI Labs" product, NI will not be supporting LabVIEW Scripting through Applications Engineering. All technical issues should be posted on the API Community.
Future Version Support
The Scripting API is subject to change between LabVIEW versions. NI makes no guarantees that any feature or behavior associated with the Scripting API will either exist, migrate automatically, or have a functionally equivalent behavior in different versions of LabVIEW.
I am not NI, but according to NI support I contacted last month it is still not officially supported:
"You e-mailed earlier about your problem with programmatically placing a probe on a wire within a VI. We do not currently support VI Scripting and as such all technical issues should be posted on the API community on the following link:
http://decibel.ni.com/content/groups/labview-apis
This stance is repeated in the download page for VI scripting:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209110
So we are unable to file a CAR at this time as VI scripting is not supported."
If anyone from NI has any hint on when that would be supported that'll be great.
Pierre-Yves
NI, that statement is ridiculous! VI Scripting has been part of the shipping product for a while now, so users would not get to see the " stance repeated when downloading it", because users would not have to download it. They just need to go to their Options menu and select in the VI Server section that they want to have access to LabVIEW Scripting.
Thanks Pierre for providing that quote.
I am ok with NI saying that the support will be done through forums, but they should probably add that to the Options menu entry, so users know where to go. Saying that it is because it is a NI Labs product is not a reason since it ha been shipping with the product for a while now.
