LabVIEW APIs Discussions
Tree API
Hejka, did you manage to download the 2015 version? Does it work?
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
Message 11 of 40
(9,999 Views)
Hello Piotr,
I downloaded attached zip file and when tried to open the project, unfortunatelly couldn't open correctly. Most of all messages are structure error and so on. Please see the attached file. Thanks in advance!!
Best Regards,
Message 12 of 40
(9,977 Views)
Thanks for letting me know. There is a bug in LV2016 with saving to previous versions. Its should be fixed by f2 patch which I installed today. I saved it again to 2015 and uploaded ZIP. Please try again.
Piotr Kruczkowski
Message 13 of 40
(9,972 Views)
Hello again, Piotr
Successfully made and installed package into my environment with no issue.
Thanks again and if I have question, contact to you again as many times as I can. 🙂
Dooyoung
Best Regards,
Message 14 of 40
(9,946 Views)
Hi Piotr and thanks for this great piece of LabVIEW-Code. I'm used to Python coding and ever missed in LabVIEW something like a dictionary-class. Your Tree API is a great substitution, and even a little bit more.
Special thanks for your quick response and updates regarding the XML on LinuxRT support. That helped us a lot. The actual version 1.6.1 works great on the cRIO 9039.
Manu
Message 15 of 40
(9,835 Views)
Im glad 🙂 please keep me up to date on how your cool project is going 🙂
Piotr Kruczkowski
Message 16 of 40
(9,825 Views)
Piotr,
I've only been using the API for about an hour, so I feel bad posting this.  It seems like there's a bug, the API vi to read the meta data of a tree, calls into the private vi.  There however, it seems like you are using the read name instead of the read meta data.  Am I completely off??
What is the use of the meta data, mostly to assign any string data to the tree item?  That's at least how I was planning to use it.  Let me know, and sorry to assume there's a bug if I'm wrong.
Jorge.
Message 17 of 40
(9,525 Views)
You are correct. I will fix it right away. Thanks for catching this.
Piotr Kruczkowski
Message 18 of 40
(9,520 Views)
Piotr,
Thanks for the update.  Regarding the API, is it possible to work with a tree that has an array data type, meaning that the user can select multiple items at once?  If I choose this, then the show tree reference has a class conflict.
Also, what is the best way to color a tree item differently based on an attribute, should I do that outside of the tree api and only use the api to read the attribute?
Thanks, Jorge.
Message 19 of 40
(9,515 Views)
1. I didn't implement it like this in the example but i don't see a problem. You just need to logically separate data items from tree items and you're good to go... I hope 😄
2. Correct, do this with property nodes outside of tree api by getting the values from it and applying them yourself.
Piotr Kruczkowski
Message 20 of 40
(9,513 Views)
